trouble starting
Old Apr 13, 2007 | 03:16 PM
mathieuhouston2's Avatar
1992 sl2 dohc. I had a previous issue with spark, figured that out after i replaced everything ignition, including the cps. When i start my car it will not idle. it will die and i apply the gas it stalls. If i start the car and pin it to the floor and hold it for a few second it runs fine after. But it always runs crappy for the first few seconds. any ideas?
Old Apr 13, 2007 | 04:04 PM
ducky's Avatar
Try replacing the engine coolant temperature sensor (ECTS). Its alow cost part, easily replaced, original one is resin tipped andprone to cracking,creating engine running problems while the replacement is brass. The two-wireconnectormay be corroded and require replacement. The single wire temperature sensor is for the dash gauge and doesn't need replacement. Both, I believe are below the throttle body. This cooant sensor is most likely the cause of the engine starting andidling problems.
BlueSaturn
Dec 18, 2010 11:51 PM
98saturnSl2
Apr 12, 2010 10:52 PM
CraigsSaturn
Apr 29, 2008 09:24 AM
antediluvian
Oct 13, 2007 07:41 AM
rickatom
Dec 11, 2006 04:56 PM
