Suspension knocking noise
Old Nov 13, 2006 | 12:25 AM
Kenmtb's Avatar
Hi all-
I have a 1998 SW2 73K and have been trying to quite the front suspension for a month. The car makes a bump/knock noise when the suspension is at the top of it's stroke. It lightly rattles when you go over bumps. The shop replaced both upper strut mount/bushings. Noise got worse.The shop replaced one of the struts. Noise went away for a weekthencame back. I noticed,when the car is bounced with the hood up, you can feel a knock at the top of the right strut tower. Should I have the other strut replaced. The shop said it wasnt leaking. Help!
Ken
Old Nov 16, 2006 | 12:49 AM
Chriscnl's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
S cars is bad for having the lower control arms bolt being loose. Check and see if those nuts and bolt are tight.
Old Nov 18, 2006 | 08:48 AM
Kenmtb's Avatar
Thanks
Ill have the nut(s) checked out. Sometimes the noise sounds like it comes from the bottom of the suspension area. Its hard to pinpoint.
Suspension
18
Jul 18, 2018 05:23 AM
wmk0002
Aug 24, 2015 10:54 PM
jbarr
Sep 10, 2012 12:20 PM
rwolf
Dec 16, 2008 09:55 AM
Gutz
Feb 24, 2008 07:06 PM
