Hi all- I have a 1998 SW2 73K and have been trying to quite the front suspension for a month. The car makes a bump/knock noise when the suspension is at the top of it's stroke. It lightly rattles when you go over bumps. The shop replaced both upper strut mount/bushings. Noise got worse.The shop replaced one of the struts. Noise went away for a weekthencame back. I noticed,when the car is bounced with the hood up, you can feel a knock at the top of the right strut tower. Should I have the other strut replaced. The shop said it wasnt leaking. Help! Ken |
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> S cars is bad for having the lower control arms bolt being loose. Check and see if those nuts and bolt are tight. |
Thanks Ill have the nut(s) checked out. Sometimes the noise sounds like it comes from the bottom of the suspension area. Its hard to pinpoint. |
