speedometor and tactometor lights out
Old Apr 19, 2009 | 01:03 PM
saturnbadgirl's Avatar
Default speedometor and tactometor lights out
i have speedometor and tactometor lights out and wondering how to fix them. also, lights on my dashboard are out. how can i fix them? if possible send me pictures on how to diassemble it and put it back together. also, what light bulbs i can use to make them brighter, if any. please send as soon as possible.
Old Apr 19, 2009 | 04:08 PM
ummm,
year and model?
have you checked fuses?
Old Apr 19, 2009 | 10:35 PM
Yeah - year and model would be a help with this ...
Brighter bulbs = more heat = more current. Maybe not a good idea ...
Old Apr 22, 2009 | 09:24 PM
it is a 2001 saturn sc2
Old Apr 22, 2009 | 09:59 PM
What makes you a saturnbadgirl, or are you just a wanna be pretender?
Old Apr 22, 2009 | 10:07 PM
As I recall, the power for the instrument lighting comes from the parking lamp fuse(10A) located in the underhood fuse block. From there, it feeds to the Body Control Module (BCM), and is controlled by the dimmer **** located on the dash. A failed (open) dimmer will keep the lights off all the time while a shorted dimmer will have the lights at full brightness. Of course, it's always possible that the BCM is bad ....
I'd check the fuse first, then the dimmer, then make sure the dimmer is seeing voltage. Oh, also, make sure the dimmer is not set to minimum. If all these things are good, then I'd disassemble the dash, and start checking the lights ....
Old Apr 24, 2009 | 09:55 PM
to sw2cam . what makes me a saturnbadgirl is that I can drive circles around you!!!!!!!!!!.
Old Apr 24, 2009 | 09:59 PM
thank you ocean archer. for the info. i will check it out.
Old Apr 24, 2009 | 10:08 PM
Talk is cheap and the cheap do alot of talking.
Old Apr 24, 2009 | 10:20 PM
Well at least we have a resident BadGirl
