sc2 1992 wont start
Old Mar 15, 2011 | 02:23 PM
andre's Avatar
Default sc2 1992 wont start
hi all,
my sc2 1992 automatic 180000km crank but wont start, i check fuel pressure at 45 psi , no spark at plug and no fuel on the plug after cranking , tried to start with disconnected ects but still no start. i swap the crank sensor with an old one nil fix. i bought a junkyard computer (not tested) ,still no start.
(the car was fine on the night but dead on the next morning ).
need help !!!!!!!!
Old Mar 15, 2011 | 04:24 PM
Foolish question, but did you check ALL fuses?
Old Mar 16, 2011 | 09:44 AM
andre's Avatar
Yes i Check all fuses and swap them also , i swap all 4 relay on the fusebox in the engin e compartiment . No luck !
Old Mar 21, 2011 | 07:18 PM
andre's Avatar
i found my problem,it was a bad ignition module (were the coil are mounted to)
Old Mar 21, 2011 | 09:56 PM
Glad you found your problem ........
SL2
May 30, 2024 08:34 PM
sorrellswilliam
Sep 14, 2010 01:44 PM
lytspdx2
Feb 10, 2010 01:49 PM
callousparade
Jul 17, 2009 02:42 PM
AudioPhyle
Nov 30, 2006 01:04 AM
