sc2 1992 wont start
hi all,
my sc2 1992 automatic 180000km crank but wont start, i check fuel pressure at 45 psi , no spark at plug and no fuel on the plug after cranking , tried to start with disconnected ects but still no start. i swap the crank sensor with an old one nil fix. i bought a junkyard computer (not tested) ,still no start. (the car was fine on the night but dead on the next morning ). need help !!!!!!!! |
Foolish question, but did you check ALL fuses?
Yes i Check all fuses and swap them also , i swap all 4 relay on the fusebox in the engin e compartiment . No luck !
i found my problem,it was a bad ignition module (were the coil are mounted to)
Glad you found your problem ........
