PCM 93 SC2
Old Feb 19, 2006 | 07:58 PM
rugerb's Avatar
I have a 93 SC2 with 100,00 miles. It use to run great, then engine light on and bad gas mileage. Spent $700 to mechanic who changed a # of things, EGR, EGR relay, temp sendors, etc........brought it to another mechanic who put it back on computer which the codes indicate the cars PCM is not working properly, sending wrong signals to car. Got another PCM from junkyard, plugged it in, car runs but not properly, doesn't shift right. Guy told me to reprogram touch negative to positive battery terminal(while still connected) to reprogram computer. Didn't really work. any suggestions would be greatly appreciated...Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!![img]smileys/smiley19.gif[/img]
Old Feb 21, 2006 | 04:44 PM
ottjoe88's Avatar
after replacing the computer it may take a bit to reset and it will shift hard for a little bt
Old Feb 25, 2006 | 08:56 AM
stevestar99's Avatar
Ottjoe is right the PCM should reprogram after couple of open road drives.I hope theguy that told you to short the battery terminals together, told you to disconnect the battery first. When you disconnect the battery, the PCM will lose it memory ina couple of minutes. With the battery disconnected, touching the terminals together just speeds up the process. If you want to reset your PCM without disconnecting the battery, pull the "PCM B" fuse (powertrain control module memory)for a couple of minutes.
cathryncay
Jul 13, 2009 08:14 PM
saturnfan1
Jul 7, 2008 09:07 AM
JOE110461
Feb 11, 2008 07:44 PM
ray3483
May 9, 2006 12:39 PM
rugerb
Apr 23, 2006 02:17 PM
