OBD-II monitor
Old Oct 16, 2008 | 10:33 AM
dsandrews2's Avatar
Hello Forum people:
I replaced the battery last week in my 1999 Saturn SL2. Then I went to get the annual emissions inspection. It failed because the battery was replaced and the monitor had not re-initiated. They tell me it has to be driven for a while to reset the monitors. Anyone know how long I have to drive it before it will pass?
Thanks,
Dan
Old Oct 16, 2008 | 06:13 PM
Happens all the time to any brand car ...... 20 miles one way down the freeway and back.
Old Oct 18, 2008 | 10:53 PM
Low Saturn's Avatar
Actually this is what needs to be done:
OBD-II Driving Cycle
If you have a 96 or newer vehicle you have the OBD-II diagnostic system. This system is constantly monitoring the sensors and solenoids on the engine. If you have replaced the battery, disconnected the battery or cleared the codes after making a repair you will need to do what is called a "Driving Cycle". This will perform a diagnostic on all the systems the computer monitors. This cycle can be done in under fifteen minutes.
To perform an OBDII Driving cycle do the following:
1. Cold Start
In order to be classified as a cold start the engine coolant temperature must be below 50ºC (122ºF) and within 6ºC (11ºF) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
2. Idle
The engine must be run for two and a half minutes with the air conditioner on maximum and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
3. Accelerate
Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
4. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
5. Decelerate
Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
6. Accelerate
Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
7. Hold Steady Speed
Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
8. Decelerate
This will perform the same diagnostics as in step 5. Again, don''t press the clutch or brakes or shift gears.
Dtruck1
May 30, 2016 11:02 PM
uncljohn
Jul 13, 2013 05:41 PM
tribefan9999
Feb 21, 2011 07:13 AM
dceyes
May 15, 2009 07:51 PM
jl582
Feb 25, 2009 05:19 AM
