NEED HELP with Troubleshooting 95 SC2
Old Jul 13, 2010 | 06:38 AM
msgtegress's Avatar
Exclamation NEED HELP with Troubleshooting 95 SC2
I have a problem that has me more than a little stumped and I'm looking to see if any of you have had this problem. I have had my SC2 since it had 50k, it now has 208K. I have a "growling" noise from the right front of the car. It started growling when turning right when car was cold and it would decrease and go away as the car warmed. I thought a PS pump at first but I figured it would growl in both left and right if it were bad, so I replaced the RF wheel bearing, growl still there, I changed the right drive axle, still there. I got sick of throwing $$ & Parts at the problem so I have kept driving it only in town to see if it got worse, it has. Now the growling seems to be there all the time (but still lessens as it gets hot) and I can now get the growling if I set parking brake turn the wheel full right put it in "D" and increase the RPM to about 1000. (car stationary). If I do the same thing with the wheel full left NOTHING.
I have changed the tranny fluid and filter religiously every 20-25k I replaced the output shaft nut at 150k.
Could this be a steering rack or something else like a motor mount
Thanks for your help!
MSgtEgress
Old Jul 13, 2010 | 10:01 AM
Right front, isn't that where things like power steering pumps and other engine mounted thingys driven by the serpintine belt live? Not to mention stuff caused by the assorted motor mounts used to keep front wheel drive east/west engines located aprox. where they belong.
Dunno, not there but have had power steering pumps on various cars get growly at full lock. Usually engine fix it stuff in a can best removes money from wallets. I have had luck with growly power steering pumps using Lucas Power Steering additive.
For what it is worth.
quitethevue
Mar 1, 2012 03:13 AM
MJSinMichigan
Nov 30, 2010 08:36 PM
kid_bender2000
Sep 16, 2010 06:10 PM
saturnguy
Apr 28, 2008 04:17 PM
getssum
Apr 8, 2008 07:04 PM
