Leaking Sun Roof
Old Dec 11, 2008 | 10:56 AM
SL2 driver's Avatar
I have a 1999 saturn SL2 with a faculty installed sunroof. The seal on the sunroof is slowing down the water from coming in, but water is still managing to get in. I think the front grooves where the water should be draining from are blocked. I have tried to unblock them but I can''t access the holes.
Does anyone have any advice on how to get the water to drain?
Old Dec 11, 2008 | 02:25 PM
Lots of people have good luck clearing the lines by using a low pressure / low volume air hose to blow the lines clear. Work from the top to do this ...
Old Feb 24, 2009 | 10:45 AM
radar2k's Avatar
i even used compressed air that you would buy for computers to clean them out...i sprayed down the line, and it seem to do the job
Old Feb 25, 2009 | 09:29 AM
Low Saturn's Avatar
Originally Posted by SL2 driver
I have a 1999 saturn SL2 with a faculty installed sunroof. The seal on the sunroof is slowing down the water from coming in, but water is still managing to get in. I think the front grooves where the water should be draining from are blocked. I have tried to unblock them but I can''''t access the holes.
RKelly5327
Saturn L300
Aug 14, 2015 09:26 AM
RaceyRaider3
Jun 11, 2015 04:40 PM
uncljohn
Aug 30, 2011 11:21 PM
cardenflyer
Jul 20, 2007 03:14 PM
ThaBean
May 2, 2007 12:32 PM
