How to test the air pump.
Old 01-31-2009, 04:57 PM
salesman11's Avatar
Hello,
I have a 2000 SL2. The air pump is not going on in the first 5 minutes of warm up, and the engine light is on, and I need to get it smogged.
(Error codeP0410.)
I replaced the valve and its running better, but no fan.
Can I run a wire to the battery and test it that way?
Can any one recomend a wrencking yard?
Thank you, Ron
It runs a little ruff, and has a hard time shifting in to high gear. I''''m thinking of trying one the those gas saver/ power booster adjusting chip.Edited by: salesman11
Old 02-02-2009, 10:36 AM
Really short answer here ... you will get more enjoyment out of your money by setting it afire on the street corner than you will by buying a ''booster'' chip ...
Old 02-02-2009, 10:58 AM
Low Saturn's Avatar
Originally Posted by salesman11
It runs a little ruff, and has a hard time shifting in to high gear. I''''''''m thinking of trying one the those gas saver/ power booster adjusting chip.
They actually have the opposite effect. You''ll loose power and the car will run so rich, it''ll waste gas, foul the plugs, catalytic converter and O2 sensors.
jl582
02-25-2009 05:19 AM
wireyourworld
01-21-2009 01:07 PM
jdmindy
12-28-2008 07:55 PM
CraigsSaturn
02-05-2008 06:39 PM
Jacques226
13
05-01-2006 12:22 PM
Quick Reply: How to test the air pump.
