Hello, I have a 2000 SL2. The air pump is not going on in the first 5 minutes of warm up, and the engine light is on, and I need to get it smogged. (Error codeP0410.) I replaced the valve and its running better, but no fan. Can I run a wire to the battery and test it that way? Can any one recomend a wrencking yard? Thank you, Ron It runs a little ruff, and has a hard time shifting in to high gear. I''''m thinking of trying one the those gas saver/ power booster adjusting chip.Edited by: salesman11 |
Really short answer here ... you will get more enjoyment out of your money by setting it afire on the street corner than you will by buying a ''booster'' chip ...
Originally Posted by salesman11
It runs a little ruff, and has a hard time shifting in to high gear. I''''''''m thinking of trying one the those gas saver/ power booster adjusting chip.
