How easy to replace 97 Sc1 oil pan
Old Oct 15, 2007 | 02:44 PM
rossjohna's Avatar
Hey guys,
can someone tell me how easy/hard it is or basically how to replace an oil pan on 1 97 sc1. I have a replacement pan, as well as a lift. I have an idea as well as the chiltons manual, just wondering if I have to loosen the motor mounts, etc or can i just get to it by removing the wheel splash guard and the reinforcement bracket and exhaust..
Thanks
Old Oct 17, 2007 | 07:58 PM
IVI4ssacre's Avatar
Have to drop exhaust down pipe. let it hang. take off pass tire and removed wheel well. take off belt. undo bottom motor mount leave top on to hold engine. remove crank pulley. while your they replace crank seal. easy and cheap. then it's 8 mm all around pan whole job should take 1 hour if its your first time. torque all 8 mm bolts to 89 inch pounds. or hand tight with 1/4 ratchet.
Old Oct 23, 2007 | 08:00 PM
portum89's Avatar
why r u trying to replace it is it leaking oil??
Old Oct 23, 2007 | 10:45 PM
Low Saturn's Avatar
Its not necessary to remove the bottom mount. You do need to remove the serpentine belt, crank pulley, exhaust down pipe, and powertrain stiffening bracket. No reason to remove any of the engine or transmission mounts.
Cdelaney
Jan 19, 2013 10:56 AM
veganxxx
Apr 29, 2011 08:23 AM
JBNJ
Oct 22, 2009 07:14 AM
Ponefish
Oct 12, 2009 10:04 AM
rossjohna
Sep 15, 2007 01:22 PM
