Horn stopped beeping :(
Old Sep 29, 2011 | 12:54 PM
kensat's Avatar
Thanks, Ill check the fuses when I get home tonite.
I do have power locks. The locks work and the dome light flashes when the alarm is activated. I can hear a relay inside the car click when the light flashes but no horn.
Old Oct 3, 2011 | 06:51 PM
kensat's Avatar
Solved:
I found a corroded wire going from the horn switch wire in the connector to the low side of the relay coil. The wire had a split in the insulation and the copper wire rotted. That was the reason there was no 12volts at horn switch wire.
Thanks for the help
Surkis
Jun 4, 2010 10:40 PM
Seth K
Nov 10, 2009 09:27 PM
Dale002
Apr 18, 2008 02:38 PM
MLmom
Apr 8, 2008 03:08 PM
gbelous
Jul 10, 2007 01:44 PM
