electrical.. daytime running lights
Old Nov 17, 2010 | 01:13 PM
fladot's Avatar
Default electrical.. daytime running lights
problem began in my 2001 L200 as bright lights coming on whenever the turn signal was active. now, it includes the daytime running lights turning themselves on when the car is off.
Old Nov 17, 2010 | 01:54 PM
As far as I know, there's only two places where these different circuits interact --> in the Body Control Module (BCM), or in the headlamp/turn signal switch.
Personally, I'd suspect that the switch is beginning to come apart internally, and I would replace it ... course, that's just me talking
Old Nov 17, 2010 | 08:33 PM
fladot's Avatar
great, the switch is the cheaper of the two (the module is unique to the 2001 saturn... so no crossover) how difficult is it to take the covers off the steering column? most switch replacements are plug out plug in... it is accessing the plugh i am concerned with.thanks so much for your help so far.
Old Nov 18, 2010 | 08:12 AM
Removing the Steering Column Covers ---
NOTE: Always disarm the airbag system before working in the vicinity of any airbag system components to avoid the possibility of accidental deployment of the airbag.
(1) On the tilt steering column, move the column to the lowest position.
(2) Remove the screws, then separate the halves and remove the upper and lower steering column covers ......
Old Nov 18, 2010 | 09:17 AM
fladot's Avatar
again, thank you. i assume the airbag will be disarmed when i remove the battery cables. is that correct or is the system mechanical?
Old Nov 18, 2010 | 09:32 AM
What mechanical device would set off the charge to deply the airbag?
Old Nov 19, 2010 | 08:50 AM
Only the sensor switches are mechanical -- the remaining portion of the system is electrical in nature
saturns_moon
Jan 24, 2014 11:20 AM
ForgottenOne
Oct 19, 2009 12:50 PM
reederk
Feb 25, 2006 01:12 AM
goetta
Sep 25, 2005 10:57 AM
satty96
Apr 16, 2005 07:43 PM
