A/C works sometime
Old Oct 8, 2018 | 10:31 AM
sadatt's Avatar
Question A/C works sometime
2008 saturn aura 2.4L i have a static pressure of 100 psi on both low and high gauge when a/c clutch engage and running. no cool when come in it cool well. can anyone explain? i am still trying to figure it out.
Old Oct 8, 2018 | 11:01 AM
The L series has a variable displacement compressor, mine stuck at zero displacement and I had to replace it. Check to see if your car uses a similar compressor, that could be all that is wrong.
Old Oct 8, 2018 | 11:21 PM
sadatt's Avatar
Thank you, I will check
Old Oct 10, 2018 | 04:02 AM
What is the benefit of this type of compressor? What controls the displacement?
Old Oct 10, 2018 | 10:33 AM
The system is controlled by an expansion valve at the firewall. Several manufacturers have used this system over the years. It allows for constant compressor operation with variable flow. My mother’s Cadillac had a similar system back in the sixties smooth operation with no clutch cycling.
Old Oct 10, 2018 | 03:55 PM
Ah, THAT'S what the thermal expansion valve does!
Another of life's mysteries solved.....
02 LW300
Apr 26, 2015 09:37 PM
Jason Derfuss
Dec 5, 2011 01:56 PM
saturnoob
Engine & Internal
May 5, 2010 03:54 PM
mark2patterson
Mar 18, 2008 08:40 PM
mark2patterson
Mar 17, 2008 09:40 PM
