Brake Problem
Old May 5, 2009 | 08:25 PM
Akramer's Avatar
Default Brake Problem
I have a 1998 SL2. The brakes work fine until I after I drive like 15 miles then the brake pedal gets hard and the brakes start to lock up on me. I have checked the fluid and that is fine. The hoses to the calipers also seem to be fine. I put new calipers, rotors and pads in the front hoping that would solve the problem but no luck. What should I check next?
Old May 5, 2009 | 08:29 PM
Powerbooster?
Old May 6, 2009 | 10:45 PM
have you flushed and bled the system?
Old May 7, 2009 | 05:57 AM
Akramer's Avatar
I have bled the system. I was thinking I should try flushing it next. Ill give that a try. Thanks.
Old May 10, 2009 | 01:31 PM
Akramer's Avatar
I flushed and bled the system. The brakes worked good for a few days. Now they are hanging up again
Old May 10, 2009 | 01:35 PM
Really sounds like you're getting air in the system from somewhere. Did you see any air come out while flushing/bleeding?
Old May 11, 2009 | 06:09 AM
Akramer's Avatar
I did have some air come out when I flushed them
Old May 11, 2009 | 07:42 AM
Hopefully, the re-bleeding of the system will take care of your problem. While you are under there, check for any suspicious indications of leaks or drips from the brake line fittings - they need to be tight
Michelle100
Jun 3, 2010 07:01 AM
Gerard3906
Nov 6, 2009 05:18 PM
murcielago543
May 21, 2008 09:24 AM
seagrave100
Mar 29, 2008 08:37 PM
duganator
Aug 9, 2007 10:44 PM
