air conditioning
Old 07-26-2007, 08:54 AM
Murrieta2003's Avatar
I have a 2003 Ion & the air conditioning sounds like it is blowing air out of the vents, but not muchair iscoming out. On the max setting, it feels like it is set on low.
Any ideas??
Old 07-26-2007, 10:21 AM
ducky's Avatar
Are you describing a restricted airflow problem or the lack of cooling? If there's a restriction there may be a linkage problem that controls the blend door that mixes hot and cold air or the door that allows outside air to the floor, face, window defrost, etc.. That blend door is the one control **** that adjusts for recirculation, face, ventilation, floor, etc.. The other **** is for adjusting the temperature from cold to hot. Unless you have auto climate control the HVAC system is manually controlled through linkages that sometimes bind.
A lack of cooling would be from a possible leak that may just have occurred. Have you tried just running the ventilation and adjusting the blower speed to listen for airflow changes at each fan speed from low to high? If the blower is operating correctly then try adjusting the mode **** from defrost to face vent to face and floor then to floor and observe for airflow direction whether re-directing the airflow is working correctly. Now try adjusting the temperature **** from cold to hot and feeling if the control works properly. Last is to turn on the a/c to feel for cooling.
Old 07-26-2007, 11:05 AM
Thanks for the quick response. I'll follow your instructions & check it this p.m.
Old 07-28-2007, 10:44 PM
MINICooperS's Avatar
Same problem . . . blower motor!
Old 08-27-2007, 03:22 PM
After following your instructions onrestricted air flow, still had no luck. The problem was the cabin air filter behind the glove box. Replaced it & the the car is like an ice box!
knclark67
09-14-2008 07:00 PM
boston547
12-15-2007 06:44 PM
CO2Man
Saturn L300
06-27-2007 11:02 PM
jennievias
03-04-2007 11:20 PM
saturn_97
07-27-2006 02:00 AM
Quick Reply: air conditioning
