ABS Light - will not go away
Old Oct 24, 2012 | 07:46 AM
Drew's Avatar
Question ABS Light - will not go away
The ABS light was on when I got the car out of a barn. I have been slowly providing it the TLC it needs to get it back to health. The ABS light was on and the scan computer was saying it was the right front wheel speed sensor. I replaced the sensor, deleted the code, but the ABS light is still on and no new codes are present. I have already changed the front brake pads, the fluid is topped off, all wiring connections have been checked from the brakes into the wiring harness. Any ideas?
Old Oct 24, 2012 | 07:52 AM
Have you tried disconnecting the ground cable from the battery for a few minutes? Maybe that would reset the computer. I don't know, it's just a suggestion.
Old Oct 24, 2012 | 09:04 AM
There's three different fuses to check --> ABS (30amp); ABS (5amp); IGN3 (30amp). All are located on the underhood junction block (UHJB). Please let me know what you find ...
Old Oct 24, 2012 | 09:48 AM
Welcome to the forum, maybe stop in the new member area and intro yourself.
Old Oct 24, 2012 | 09:45 PM
Drew's Avatar
I have tried the battery, both shortly after I cleared the codes and again this evening with no luck. I appreciate the effort.
Old Oct 24, 2012 | 09:48 PM
Drew's Avatar
I did not have time this evening, but I have tested the ABS 30amp fuse previously, but I have not check the others. I will let you know. Thanks!
RjION
News, Updates & Announcements
Jan 6, 2012 12:08 AM
JustinsSaturnSL
Aug 9, 2011 10:34 AM
notjustquilling
Jan 5, 2009 09:42 AM
btc1572
Jan 14, 2006 11:16 AM
elkslayer69
Sep 29, 2005 06:25 AM
