93 to 92 sc2 engine change help
Old Oct 21, 2008 | 02:35 PM
7894steve's Avatar
i am looking for some acurate info on an engine change project i am taking on. this is it, i had a 92 sc2 w250k, ran great but used oil, got 40+ on the highway. i smashed it and got a 93 sc2. i want to rebuild the 92 motor and put it in the 93.i took apart the 92 and it looks good for a rebuild inside. i have heard alot of talk of the reluctor ring on the crank being different from 92 to 93 and throwing the timing way out. can anyone tell me if this is true, and if in fact i can or can not use the 92 motor in the 93. any info will be helpful. thanks anyone
Old Oct 23, 2008 | 10:05 AM
Atlaswar's Avatar
Yes the cranks are different.
Check your ecm connectors first. If they match...try a brain transplant
Old Oct 29, 2008 | 05:58 AM
Atlaswar's Avatar
Steve
Sorry I took so long getting back to you.
You have two choices: Get a 92 crank and install it in the 93
Or take the chance and splice the connectors to install your PCM
As near</span> as I can tell the control architecture is the same, just different connectors.
If you do decide to splice. Check a few various points at the pcm on both units to ensure they go to the same sensor. Definitely check the injectors, Crank position sensor, and the throttle position sensor.
LUCK
Old Oct 29, 2008 | 08:27 AM
7894steve's Avatar
thanks for the info, i will look into it. steve
Slimbob2932
Jun 10, 2010 08:35 PM
GRETSCH43
Saturn Aura
Oct 1, 2009 09:36 PM
DaniSC2
Engine & Internal
Apr 30, 2008 09:08 PM
DaniSC2
Apr 30, 2008 11:41 AM
B3SL1
Aug 4, 2005 09:49 AM
