2005 Ion Signal Problems
Old Sep 7, 2020 | 11:15 AM
grasp's Avatar
Default 2005 Ion Signal Problems
I could really use some help. I have a 2005 Ion and the front turn signals are not working. The rear ones are working. When the turn signals are turned on, only the rear ones flash. When the hazards are turned on, again, only the rear ones flash. The bulbs are good and the parking lights do work. Any ideas?
Old Sep 7, 2020 | 09:14 PM
Do you have 12v appearing at the bulb connectors? With the turn signals engaged?
Old Sep 8, 2020 | 06:36 AM
I'm not at all familiar with the Ion, but I have seen some cars with fuses for the turn signals in the fuse box. Have you looked for anything like that? Like derf said, you must not be getting 12 volts to the bulb. A broken ground wire could also be the issue.
RonnieJoseph
Nov 19, 2017 12:49 PM
lintg03
Saturn Outlook
May 31, 2017 11:40 PM
dwd375
Jul 29, 2015 04:19 AM
smyly35
Nov 8, 2010 09:56 PM
alex_0227
Apr 4, 2009 09:58 AM
