start and die help!!!
Old Feb 7, 2008 | 04:50 PM
billgrim04's Avatar
is there some kind off roll over switch on the 96 saturn sc1 for when it goes on its side then pushed back over because this thing will not start back up
Old Feb 7, 2008 | 05:57 PM
original007's Avatar
no
Old Feb 7, 2008 | 07:15 PM
Low Saturn's Avatar
Did you roll your SC1?
Old Feb 27, 2008 | 12:02 AM
billgrim04's Avatar
no my friend put it on its side but it was fine it didnt really hurt the car like i said i shut the car off after he got out of it and then a tow truck driver pulled it up the hill and after that it wouldnt run agin
Old Feb 27, 2008 | 09:58 PM
ok fuses blown?can you hear fuelpump run is there fuel pressure,spark? got to get the basics fuel,compression and spark
Old May 29, 2008 | 08:52 PM
Vultures Eye's Avatar
Sounds like a problem with the idle air bypass valve being stuck closed. It is easy to replace and cost around $75. It is screwed into the side of the throttle body, is about 1" in diameter and has a 3 wire connector. The throttle body sits on top of the engine and is where the air enters the engine. Go to the parts store and buy the new one and you'll know what it looks like.
____________________
My blogs "My Car Tool Kit"
Old May 30, 2008 | 09:52 AM
Low Saturn's Avatar
The car would still start if the IAC was bad.
Old May 30, 2008 | 02:34 PM
But how? You mean my dealer rip me off? it happen to me 3 months ago. Can I get some details?Edited by: Vultures Eye
Old May 30, 2008 | 03:28 PM
Low Saturn's Avatar
99% of the time IAC valve normally sits in the closed position. It slightly opens to allow more air in at a cold start to raise the idle speeds to aid in engine warm up.
jcoll72305
Jan 24, 2013 09:45 AM
ryankhemraj
Nov 1, 2010 10:26 PM
Raab_himself
Dec 16, 2009 11:03 PM
DaughtersSL2
Nov 25, 2008 08:56 AM
taylor
Mar 8, 2008 08:20 PM
