is there some kind off roll over switch on the 96 saturn sc1 for when it goes on its side then pushed back over because this thing will not start back up
no
Did you roll your SC1?
ok fuses blown?can you hear fuelpump run is there fuel pressure,spark? got to get the basics fuel,compression and spark
Sounds like a problem with the idle air bypass valve being stuck closed. It is easy to replace and cost around $75. It is screwed into the side of the throttle body, is about 1" in diameter and has a 3 wire connector. The throttle body sits on top of the engine and is where the air enters the engine. Go to the parts store and buy the new one and you'll know what it looks like.
____________________ My blogs "My Car Tool Kit" |
But how? You mean my dealer rip me off? it happen to me 3 months ago. Can I get some details?Edited by: Vultures Eye
99% of the time IAC valve normally sits in the closed position. It slightly opens to allow more air in at a cold start to raise the idle speeds to aid in engine warm up.
