New here and have a BIG PROBLEM!
Old Sep 21, 2007 | 09:04 AM
Low Saturn's Avatar
Yep, thats a TwinCam engine. Why is the exhaust manifold all wet?
Originally Posted by SL2510
Heres a pic of the engine. Hope that helps
Old Sep 21, 2007 | 03:00 PM
SL2510's Avatar
I beleive its from the oil leak?
The engine hasnt been touched in about 2 weeks or so.
Could be some kind of lubricant?
Old Sep 21, 2007 | 03:09 PM
Low Saturn's Avatar
The only way foroil to leak way up there is due to the valve cover gasket leaking.
Real easy to fix. The gasket it roughly $25 at the dealer and requires a 10mm socket and ratchet to replace. A torque wrench is helpfull too. Too loose and it will leak, too tight and it will leak. And you'll break the bolts.
And if its leaking that bad from the front, its gotta be just as bad in the spark pug wells. And that would cause it to run pretty bad. It's very possible that you can fix your problem yourself and save $1175 in the process.Edited by: Low Saturn
LarryG
Aug 27, 2011 07:55 AM
Maroon97SL
Jun 6, 2011 05:05 PM
haywood11
Aug 14, 2010 08:18 PM
JKCAS8704
Apr 16, 2007 06:42 PM
GSXR1000
Nov 16, 2006 12:30 AM
