need 2 fix water pump on 92 sc dohc
Old Mar 26, 2007 | 04:54 AM
saturn2low's Avatar
just bought a 1992 saturn and i need to fix the water pump . should i buy the book from autozone does it have all the info on changing out the water pump ??
Old Mar 29, 2007 | 10:46 PM
If you have mechanical abilty the book will be help. Edited by: sw2cam
Old Mar 31, 2007 | 10:32 AM
Chilton book (91 to 93 S-cars) has pretty detailed instructions
Old Apr 7, 2007 | 05:13 AM
Low Saturn's Avatar
<DIV id=post_message_605730>Lift the car up on jack stands, remove the passenger side wheel and splash guards. Put the jack under the oil pan and put enough tension to support the engine without lifting it. Then remove the upper mount and lower dogbone mount. Now you can lift the engine up and down with the jack to gain access to all the bolts. Drop the engine to get access to the pulley bolts. Its much easier to remove these with an impact gun, but can be done by either leaving the belt on or using a strap wrench. The bottom bolts of the pump can be easily reached by lowering the engine all the way, and the top bolts by lifting the engine all the way.
Replacement shouldn't really take more than a half hour to 45 minutes.</DIV>Edited by: Low Saturn
Old Sep 9, 2007 | 12:04 PM
Low Saturn's Avatar
Originally Posted by anthonf
If your saturn water pump uses "O" rings instead of gaskets, do not use silicone. Just remember to clean up ALL the surfaces that the rings will seal against. This will avoid leaks when you finish. <STRoNG style="FONT-WEIGHT: normal">Always use the right torque settings when installing anything with a gasket. If you over tighten, you can wreck the gasket before you even start the car. If it’s not tight enough, you’ll get leaks.[/b]
The Saturn water pump uses a preformed silicone gasket.
Old Mar 2, 2009 | 08:12 AM
RonR's Avatar
I replaced one on my 97 sl2. I did not remove the engine. the bolts sre tight in there but it can be done. I went in from underneath at the pass side wheel well.
Old Mar 2, 2009 | 05:51 PM
Similar here ... top and right side work.
Bill Berger
Jun 12, 2014 01:32 PM
Indica
Sep 27, 2007 08:22 AM
jisham
Dec 12, 2006 12:14 AM
cbaa1970
Apr 14, 2006 01:09 PM
starless127
Jun 16, 2005 02:40 PM
