camshaft position sensor??
Old Jan 1, 2008 | 07:00 PM
97sc1's Avatar
hey im new to saturns, ive worked on dodge, mitsu, and toyota since ive been a mechanic. now i pulled a code form my saturn sayin sumthin wrong with camshaft position sensor. now thats fine and dandy, but i cant find a store that carries the part, most of the stores have even said that they dont have tha part listed. now my question is, does the part go by a differant name or are the parts store monkeys stupid, any info on this will be greatful.
< =text/>
_uacct = "UA-939292-47";
urchinTracker();
Old Jan 5, 2008 | 03:17 PM
original007's Avatar
P0341 NOT REALLY A CPS REPLACE THE 1/4 COIL
Old Jan 6, 2008 | 11:37 AM
Low Saturn's Avatar
Saturns dont have a camshaft postion sensor because the ignition module uses capacitive pickup plates located under the 1/4 coil pack to determine the polarity sequence and voltage amplitude of the cylinder 1/4 secondary ignition. The PCM supplies 5 volts on the signal line and expects to see the cylinder #4 signal wire go low after every 14 crankshaft pulses (2 revolutions). This is used to determine the position of the camshaft. Also when referring to a CPS in a Saturn, its the Crankshaft Position Sensor.
And if your getting a P0341 its unlikely it needs a new 1/4 coil pack. Check for corrosion on the terminals at the coil, fouled spark plugs, bad wires or oil in the spark plug well #4. 99% of the time, its one of those four things.
Edited by: Low Saturn
Old Sep 20, 2025 | 01:25 PM
reaper7427's Avatar
< =text/>
urchinTracker();
need to remember Saturn has been out of business for years so finding parts is getting more difficult cause Saturn doesn't make them any more
Old Sep 20, 2025 | 02:01 PM
Welcome to the forum, please limit responses to your knowledge level. Your response is incorrect and misleading in this case.
This thread is also from 2008 so maybe you are a Bot.
Old Sep 20, 2025 | 02:42 PM
Banned.
If you're an actual person and want to join and not give vague incorrect answers to 17 yr old posts that have already been answered , create another account from a different IP address and make your username your email address first section backwards.
d0ugparker
Jul 31, 2025 10:36 AM
Amandalairmore78
May 18, 2025 09:53 AM
thepruit
Jun 3, 2009 10:37 AM
dceyes
May 15, 2009 07:51 PM
prawlings1
Aug 5, 2007 02:33 PM
