Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification... let's hear about it here...
Stock Swap
Old Mar 19, 2010 | 07:47 PM
Raab_himself's Avatar
Default Stock Swap
Hey guys, i got a 99 Sc1, my stock cd player just went on the fritz. I was gonna go to the wrecker and get a used one from the same year but then it struck me...maybe i could put one from a newer year in???...maybe one that plays mp3's and such...would the wiring be the same? And i guess would a newer one fit? i know i really should just buy a new aftermarket but thought this would be a little different.
Old Mar 19, 2010 | 08:51 PM
If I remember ......... 95-2001 are the same
Old Mar 20, 2010 | 02:45 PM
If you utilize a low-end Saturn unit to replace a low-end (budget) Saturn unit, the connections should be identical. If you got a high-end unit and replacing with a high end unit, that should be OK too. Your problems will come in if you go low to high, or high to low, or after market. In those cases, you'll need to buy/make an adapter cable. Good luck
Old Mar 20, 2010 | 05:49 PM
i thought it was 95--99 if you look on ebay they will usually state it
dont just go off one listing check a few
Old Mar 20, 2010 | 08:46 PM
riffee's Avatar
95-99 is right
Old Mar 21, 2010 | 07:38 AM
Derf you right .............. forgot they changed on the third gen
Old Mar 21, 2010 | 08:08 AM
i try
Old Mar 23, 2010 | 07:51 PM
We love the way you try
95-99 is the answer
Old Mar 23, 2010 | 10:00 PM
if at first I don't succeed I cry and cry again
crhammondusn
Jun 10, 2008 06:14 PM
TheEngineer
Jun 9, 2008 12:00 AM
mikes 1994 z28
Engine & Internal
Apr 7, 2007 11:50 PM
S-Turn
Feb 9, 2007 03:41 AM
goat
Mar 4, 2006 12:33 AM
