ABS Light/Computer
Old Jan 11, 2006 | 04:41 AM
btc1572's Avatar
Recently I purchased a 1997 Saturn SL with the ABS light on. I have a mechanic who works on my cars and he has a Snap-On code scanner. The car's computer will not respond to the scanner. It comes up with the brake-switch code then just goes blank. I have replaced the entire ABS module as well as the brake switch and I am still having the same problem. Can anyone help?
Old Jan 11, 2006 | 07:38 PM
did you just replace the module, or the whole mastercylinder? It is easy to mess it up if you try just replacing the module. I just had the same problem and it was the abs controller. I got a abs master cylinder with the module from a wrecking yard, put it on, and it was fixed
Old Jan 12, 2006 | 11:42 PM
btc1572's Avatar
I did that, actually. I got an entire unit from a wrecked one and installed it. Still having the same problem. I even changed the brake switch!!
Old Jan 14, 2006 | 11:16 AM
stevestar99's Avatar
Was the usedmodule from a car that had been in a front end wreck? It may just be me, but buying used brake and/or electronics is a 50/50 crap shoot at best.
Drew
Oct 24, 2012 09:48 PM
redheaddeb
Aug 13, 2011 06:29 AM
notjustquilling
Jan 5, 2009 09:42 AM
mfre1111
Mar 24, 2008 10:31 PM
belladiva1
May 2, 2007 01:39 PM
