engine starting/fuel pump
Old 02-22-2007, 10:39 PM
rickatom's Avatar
I have written about this before, but I need to make sure I know what I am talking about.
I have a 1997 Saturn SC 2dr with the 1.9 engine. My problem is or seems to be, not getting fuel to the engine when first turning the key. It takes a few times before the gas gets there to finally start the engine.
I have been told, "it is the fuel pump, allowing the gas to get by and drain back into the gas tank". Is there a checkvalve built into the pump or is it somewhere else??? Am I looking to replace the pump, which is working or a checkvalve which is not.
Also, I thought I read somewhere, that there is a trap door that I can access to replace the pump without dropping the gas tank. Where is this located? Is it under the back seat or in the trunk somewhere?
Thanks
Old 02-23-2007, 02:17 AM
97 fuel pumps do tend to allow fuel pressure to bleed off between starts.
Ones that were massively defective were extended warrantied (up to 100K I believe)
Workaround:
Turn the key to run, listen for the fuel priming "hum", then a click when the hum ends.
THEN turn the key to START.
Once primed, the car should start right up. Saves wear on the starter, and total cost is 5 seconds per start ($0).
I have 195K on my original 97 SC2 fuel pump--this trick works like a charm.
Derf
Edited by: derf
Quadcouper
02-02-2014 04:13 PM
JRN Racing
06-03-2007 07:21 PM
neil18
03-18-2007 01:25 AM
rickatom
03-12-2007 02:09 PM
notorious-sl1
12-22-2006 03:57 AM
Quick Reply: engine starting/fuel pump
