I have written about this before, but I need to make sure I know what I am talking about. I have a 1997 Saturn SC 2dr with the 1.9 engine. My problem is or seems to be, not getting fuel to the engine when first turning the key. It takes a few times before the gas gets there to finally start the engine. I have been told, "it is the fuel pump, allowing the gas to get by and drain back into the gas tank". Is there a checkvalve built into the pump or is it somewhere else??? Am I looking to replace the pump, which is working or a checkvalve which is not. Also, I thought I read somewhere, that there is a trap door that I can access to replace the pump without dropping the gas tank. Where is this located? Is it under the back seat or in the trunk somewhere? Thanks |
97 fuel pumps do tend to allow fuel pressure to bleed off between starts. Ones that were massively defective were extended warrantied (up to 100K I believe) Workaround: Turn the key to run, listen for the fuel priming "hum", then a click when the hum ends. THEN turn the key to START. Once primed, the car should start right up. Saves wear on the starter, and total cost is 5 seconds per start ($0). I have 195K on my original 97 SC2 fuel pump--this trick works like a charm. Derf Edited by: derf |
