Vue swap
Old Dec 19, 2023 | 10:58 AM
Chris962's Avatar
Default Vue swap
Hi all,
new to forum and looking for any info/thoughts on swapping a 04 V6 and transmission(MJ7)(FWD) into a 03 Vue 2.2L CVT model.
The 03 transmission went at 130,000 and there is a slight knock in 2.2, the body and interior is like new on 03, whereas the 04 has a bent frame and trashed interior along with electrical issues concerning the interior(BCM?)
Any thoughts or direction on this is much appreciated.
Thanks for looking!
Old Dec 19, 2023 | 04:33 PM
I'd be very surprised if it couldn't be done. However we don't have a Vue expert on the forum right now.
​​​​​@DropDead , what do you think?
We'll see if he stops by. If not, I can refer you to another site that likely has write-ups on doing the transition, I mean transmission, I mean swap I mean you know what I mean
Old Dec 20, 2023 | 05:29 AM
This swap is not for the feint of heart. If the sheet metal is the same then the swap is a bolt together. The four and six cylinder L series cars share sheet metal. I would want to solve the bcm issues with the donor car before continuing with plans to swap. The entire wiring and mechanical parts will need to be moved.
Old Dec 20, 2023 | 12:49 PM
Chris962's Avatar
Thank you sir!
Old Dec 20, 2023 | 12:55 PM
Chris962's Avatar
That was my thought, literally swap everything that could be swapped(BCM,ECM obviously) and accompanying harnesses along with everything else that I could concerning drivetrain,and electronics. one of my concerns was motor mounts, I had read that they were not a direct swap and haven't been able to find any idea of what needs to happen.
Thank you sir!
Old Dec 21, 2023 | 11:34 PM
DropDead's Avatar
I'll check back in tomorrow when I'm awake. It should essentially be a direct swap. Assuming both cars are optioned the besides the drivetrain difference, you may be able to get away with just swapping modules.
look up the body harness p/n for each vehicle per vin.
And yea, I'd figure out the electrical issue before I started the swap
Old Dec 22, 2023 | 08:45 AM
Chris962's Avatar
Great idea about harness part number! I will see what I can find out,
Yea electrical gremlins will have to be sorted, Buddy that owns it said sometimes tach doesn't work(ECM or short? ) And interior fan stays on regardless if on or not. Stereo was robbed out of it a few months back while it was in his garage after accident which bent frame in back, he said that's when the gremlins started.
Thank you!
Old Dec 26, 2023 | 10:19 PM
DropDead's Avatar
Thank you!
Gremlins started after it was hit? Or after the radio was taken out?
The tach and the blower motor sound like 2 different issues.
Where are you located? I may be interested in the knocking 2.2 if close enough and it's not a complete destroyed engine
Old Dec 28, 2023 | 10:39 AM
Chris962's Avatar
Sorry for delay, Holiday/family stuff.
He said it started after radio was yanked out, maybe damaged harness some how? But I thought maybe he didn't notice tach not working until he parked it.
Located in East Orlando area.
Old Dec 28, 2023 | 09:59 PM
DropDead's Avatar
Kinda sounds like something was damaged in the process of removal. Dash harness may be the same between the two cars, though.
Eh Orlando is to far for me to drive
