VTI fluid Question
Old Jan 3, 2015 | 09:50 PM
firemedic2572's Avatar
Default VTI fluid Question
New guy here with a question. Looked back 5yrs and did not see anything in the thread about this. Sorry if there was one and I missed it. I have a 03 2.2 AWD VTI. Trans has been shuttering when first taking off. I understand these are a problem child now 2 years after buying it to keep miles off my truck for the work commute. My plan was to change the fluid, following the procedures I have found online with the drain tube and using a reader to know temp. What I was wondering was can I used the aftermarket fluids made for CVT vehicles without adding any other modifiers? I have found the valvoline fluid at a local store. Thanks for any help you guys may have.
Old Jan 3, 2015 | 09:53 PM
--NO--
Unless you want it to die sooner than later. Either it's gonna die, but why rush it.
Top right of most pages you'll see your username. Next to it a drop down, click it. Add your first name, location, and car to your "signature". Stop in the new member sub-forum and introduce yourself to the gang.
Once you reach 25 posts send a jpeg (photo) to me and I'll set you up with an avatar. If you do not reach the minimum 10 posts your account will be shut down as inactive.
send to
sw2cam@yahoo.com
Subject line "AVATAR"
Old Jan 5, 2015 | 04:16 PM
Thanks for responding. Can I use the valvoline cvt with the gm additive #15231847? Shipping on a syringe is much cheaper than a syringe and 2 gallons of oem.
Old Jan 5, 2015 | 09:58 PM
I doubt his answer will be any different than the first.
Have you consulted a GM dealer parts department?
RjION
Feb 5, 2017 08:27 AM
dredawg10
Oct 10, 2013 07:19 PM
gpsman4
Jan 19, 2009 04:01 PM
swilson21
Feb 16, 2008 09:34 AM
hummvue
Feb 1, 2007 03:11 PM
