Sudden total electrical death, '04 Vue, first owner
Old Sep 14, 2015 | 12:29 PM
scoffman's Avatar
Originally Posted by andrewjmorin
I'm treating it as a bad ground, cleaning and greasing all my contacts today, and keeping an electrical emergency kit in the car from now on. . .
Not sure what you mean by greasing all my contacts, but if you are putting dielectric grease on your ground terminals between the body surface and the connector surface, then there is your problem. dielectric grease is an insulating compound to be used for sealing and lubricating purposes. You should only put it on the outside of the circuit after a clean surface to ground connection has been made to help seal the connection from outside elements that might cause problems i.e. water, oxygen.
Old Sep 15, 2015 | 06:58 AM
My oldest brother once "redid" all of the wires in a trolling motor using Liquid Solder and wondered why it wouldn't work. He thought because the name "solder" was in the name of it, that it would conduct electricity!
Old Sep 21, 2015 | 04:55 PM
andrewjmorin's Avatar
Put over 1000 miles on her last week, calling this problem solved.
This thread saved me hundreds of dollars in troubleshooting costs!!
Thanks Derf!
Old Sep 21, 2015 | 08:40 PM
You're quite welcome. What was the solution?
Old Sep 22, 2015 | 09:49 AM
Took the battery out and cleaned all the connections, including the chassis ground.
I also invested $9 to have an ignition relay on hand if that turns out to still be a thing, but so far it's been clear sailing.
Old Sep 22, 2015 | 06:49 PM
like I said in my first post --- go for the simple stuff first
baconman1982
Dec 9, 2014 07:09 AM
ElCheapo
Nov 2, 2012 05:12 PM
Squiz
Jun 3, 2011 06:38 PM
06vueDriver
Jul 20, 2009 09:56 AM
sirfodder
Jul 19, 2006 01:30 AM
