Front end shudders?
Old Jul 10, 2025 | 04:01 PM
coge4419's Avatar
Originally Posted by Stove
I put new strut assemblies in and new sway bar links but my front end feels the same. Clunks on bumps and sometimes has a shudder feeling. Like the front is wiggling. The subframe mounting points look ok. No rust holes in unibody. The control arm bushings look ok. I preyed on them with pry bar and deflection seemed ok. I checked each wheel bearing and no play. What’s next? New control arms?
I'm at where youre at. Completetly rebuilt the front end including control arms, but did not replace cv or rack and pinion. I have 240,000miles on my 2006 Vue. I know its one or the other. I have had a tear in my CV boot for over a couple years, so likely it may be going out anyways, but the clunks and shudder's you describe I have as well when i hit bumps at low speeds. The only other symptom i have is a vibration that shows up around 75mph. I believe it's my rack and pinion
Aug 22, 2023 10:59 AM
tarturo2004
Aug 7, 2019 08:53 AM
mconnelly
Jan 21, 2017 07:59 PM
ktmac
Sep 11, 2009 05:33 PM
Nov 2, 2008 05:32 AM
