CVT to Automatic or 5 speed conversions
Old Feb 9, 2020 | 07:19 PM
  #21
charlescjensen's Avatar
Quick question...for the clutch master cylinder, I assume you cannot cut the center hole and use the existing studs for mounting?
Old Feb 10, 2020 | 08:33 PM
  #22
blaisa's Avatar
I have a template which I use to mark the holes in the firewall. I use a hole saw for the center hole and drill out for the mount bolts. I take a picture of the template when I in my shop tomorrow so to give you some idea as to what it looks like. I know one of the bolt holes lines up with one of the studs which is in the firewall. I drill straight through it.
Old Apr 6, 2021 | 05:46 PM
  #23
Reggie Sanders's Avatar
Default Help!
Originally Posted by blaisa
Not sure if folks have a need for this information but I have done several successful swaps of the CVT Saturn Vue's to Saturn Vue 4 speed automatics and 5 speed standard transmissions. I can provide parts lists as well as modifications required if need be.
could you send me how you modified the wiring for your vue I am at a loss, my vue vti / cvt transmission and out. I was doing the swap to the af23 5 speed auto trans out of an 04 ion.
I got the wire harness,
Torque converter,
New mounts ( trying to figure out front and back brackets)
Tcm and ecm from donor car.
Is there anyone who has done the wiring correctly? Because my ecm is different.
Old Apr 7, 2021 | 12:57 AM
  #24
Read the rest of the thread. I think the files themselves are attached in one post and the rest of the thread are the actual instructions.
Not sure if you will hear from the original poster.
Old Jul 31, 2024 | 08:18 PM
  #25
Alan's Avatar
I have a 2004 Saturn Vue 4 cylinder on its 7th transmission automatic it will need to be replaced Don't want to spend a lot options ?? Manuel, Honda conversion, or Used or rebuilt I like the car and don't drive far.
Old Jul 31, 2024 | 09:25 PM
  #26
You replaced the CVT with 6 rebuilt cvts?
Old Aug 1, 2024 | 10:32 AM
  #27
blaisa's Avatar
You are much better off either junking the Vue or converting it to a manual 5 speed. The CVT transmissions in the Vues are pure junk.
Old Aug 1, 2024 | 12:29 PM
  #28
Welcome back, sir!
Old Aug 2, 2024 | 01:03 PM
  #29
blaisa's Avatar
Welcome back, sir!
Thanks! It has been a long time (years) since I did any manual conversions for anyone. I moved on to 2015 and up Mustang's.
Old Aug 2, 2024 | 11:05 PM
  #30
Well, you hold a slice of Saturn knowledge all your own.
04bonez
Sep 25, 2024 08:07 PM
charlescjensen
Feb 9, 2020 10:22 PM
Nayte Senn
Jul 25, 2018 08:43 PM
buzzchamp33
Oct 31, 2014 11:54 PM
jjimmy
May 8, 2013 08:10 PM
