Cps replaced all 4 now getting all 4 codes. P0016-p0019
Old Sep 20, 2024 | 06:15 PM
River's Avatar
Default Cps replaced all 4 now getting all 4 codes. P0016-p0019
Only had 2 cps and 1 crankshaft ps code. Decided to replace all 5 in total and a couple other sensors. My check engine light went away however now I’m getting all 4 codes for the cps sensors. Erased the codes multiple times but the moment I start the vehicle up again they instantly come back. Don’t really wanna take them out to return them because it’s running just fine and the check engine light is gone. But this seems really odd. Thanks in advance for any help.
Old Sep 20, 2024 | 10:36 PM
If they are P codes, your check engine light should be on, unless they are followed by a P for pending which means the vehicle is still evaluating whether or not the malfunction is real.
So I'm assuming you have all four CMP codes pending.
Are you sure you used the correct part numbers when ordering / what you ordered is what you actually got in the boxes?
What other sensors did you replace? We have no idea.
Thank you.
Old Sep 21, 2024 | 08:26 AM
Maybe it just needs a few drive cycles before it returns to normal?
Old Sep 21, 2024 | 11:04 AM
Rube,
You may be right
I may be crazy
But it just may be a lunatic you're looking for....
If the codes were already cleared before the repair AND the repair was successful, the codes shouldn't have set, hard code or pending, after the repair. Plus some of the codes present now are new codes.
If the codes were not cleared before the repair, then the hard codes would have had to disappear to turn off the check engine light, followed by all four codes setting as pending, some of the codes which were not present before.
Old Sep 21, 2024 | 08:54 PM
Do we have any idea which VUE he is dealing with? 3.0, Honda or late GM v-6?
Old Sep 22, 2024 | 01:03 PM
No idea, Andy. Such information wasn't provided as you can see.
Old Sep 22, 2024 | 07:35 PM
I think the last generation had the 3.5 and 3.6 gm v-6. They might have vct and four cam sensors.
Old Sep 22, 2024 | 10:36 PM
You are correct Re: 2nd gen vue V6 s_
Blacksmith1
May 10, 2024 06:28 PM
punkrockgurl606@gmail.com
Oct 27, 2021 08:12 PM
slsail
Mar 21, 2011 07:52 PM
thepruit
Jun 3, 2009 10:37 AM
DavidBunin
Apr 22, 2007 09:33 PM
