Anyone parting out 2007 Vue AWD?
Oil pan
https://www.gmpartsgiant.com/parts/gm-pan-oil-12582338.html?vin=&make=Saturn&model=Vue&year=2007 &submodel=&extra1=&extra2=&filter=(e=L66;t=MJ7;m=Z LN26)
Rear drive shaft
You will not find this without searching on the term "propeller shaft". One of the GM part numbers is 25775163. I'm not positive that is the correct part for your car, and there are other parts needed to hold it up etc.
GM lists it as discontinued but others list it online.
Have seen prices from $300 to $900 but there seems to be confusion over exactly what the part number pertains to. You'll see when you start looking.
Rear drive shaft
Thank You
Thanks for the info…
I got around to putting it up on ramps.
Found my right front wheel well skirt was the source of an annoying noise I kept hearing, as well as learning the “flywheel dust cover” is amongst the missing, as well as a bolt missing for some sort of frame connector from the floor pan “frame tube” (the head is snapped off), as well as a nice rust hole in the “rocker”.
Bolt missing… hope this ain’t important!!! Head snapped off, time for easy out
Surface rust
Right rocker
Can’t find this on any parts website.
Floor pan
Fat fingers!
Left side is rusty but no hole yet..,
I’m gonna post some pics either here or my newbie post.
Surface rust
Right rocker
Floor pan
Fat fingers!
Looks like I can get a drive shaft and hardware for $100
oil pan for $50
and that flywheel cover for probably $10 with the bolt
Plus shipping. If I can figure out the length of the driveshaft, I can get a quote if you are interested. Let me know what your zip code is. I can go this weekend.
So figure 160 plus shipping. And I will cover paypal fees.
oil pan for $50
Rough estimate, shipping is almost $300 (ouch) due to being considered oversized. From what I can find, the shaft is about 81in long.
IF the shaft can be separated (id imagine in can be) shipping would be roughly $100.
Either way, pricey.
If you dont want to spend that kind of money, I can get a quote on just the pan and flywheel cover thing for yuh.
I am planning on going saturday morning as I have an engine to yank out of an aveo sunday to send to the machine shop.
Either way, pricey.
ok...
I want to look into this rot I've got going on...
I thought I had found the source of a noise in the front end. I found the skirt near the oil filter hanging on by like two fasteners.
I put all of them in and the spoiler was missing three as well.Took it for a ride, the noise is still there? It isnt loud or anything, just annoying.
So I'm searching for parts and parts diagrams and found some links, one looked very interesting. Same rust problem that this fella had.
Right in front of the wheels there is a "bushing" or spot where it looks like the inner fender kinda connects to the engine cradle. (i think)...
Both sides. Maybe I should start a new thread... I'll search the forum too. I am posting the pic again, and the link to this guys issue and fix. He actually did a great job. I just don't have that kind of access to things I would need to fix it. Maybe I can get a body shop to check it out. Although I actually really like this little suv, it might not be woth it.
Any idead anyone? Thanks and apologies for the bouncing around of issues. maybe I could find a dead one in the south that the body would obviously be better?
Chow for now.
Do you or a family member own a 1st gen Saturn Vue? | For C Bodies Only Classic Mopar Forum
Should I not drive this thing?
Chow for now.
