2009 Vue XR what size bolt holds the A/C clutch ?
Old May 16, 2018 | 04:18 PM
Andrew Carey's Avatar
Default 2009 Vue XR what size bolt holds the A/C clutch ?
Hey everyone. I am attempting to work on my mothers 2009 Saturn Vue XR because she complained her A/C wasnt worked. I went under and saw that the entire clutch coming out of the compressor wasnt even bolted on anymore. I dont know what size bolt held the clutch on and I am trying to purchase just the bolt to see if its an easy fix (doubt it, but Id rather try instead of purchasing an entire new compressor assembly)..
Does anyone know the correct size of the bolt ?
Old May 19, 2018 | 08:35 PM
bump.
Old May 19, 2018 | 10:26 PM
I answered your other post. Did you look and see if the original bolt had broken off in the shaft? It is probably 6 x 1.0 by about 20 mm long.
Old May 25, 2018 | 12:21 AM
why do you have two posts on the same subject?
I'll delete one of them.
www.tonkinonlineparts.com
Best place I have found as far as exploded diagrams go.
Look it up.
vuehybrid
May 27, 2015 11:28 AM
raedar
Aug 11, 2009 09:09 PM
KCKIM
Nov 28, 2008 08:09 AM
trysten
May 12, 2008 06:43 PM
2000saturnsl2
Mar 16, 2008 04:28 PM
