2008 Vue Skirt Rocker Panel Removal
Old Mar 23, 2024 | 01:02 PM
RustBot's Avatar
Default 2008 Vue Skirt Rocker Panel Removal
Hi there,
Anyone have any idea on how skirt rocker panel is removed?
This is the panel that goes from wheel to wheel under both doors and is plastic. I have removed the screws to rear of front wheel and screw ahead of the rear wheel and all of the nylon retainers on the underside of the panel. Is it possible there are trim clips on back side of panel. I want to remove panel to address rust behind it.
Thanks for any assistance provided.
Old Mar 23, 2024 | 07:46 PM
grcauto8453's Avatar
Look around in here for it.
Follow the breadcrumbs.
https://charm.li/Saturn%20Truck/2008.../Trim%20Panel/
Old Mar 23, 2024 | 11:30 PM
My L has push pins on the bottom also. Don’t know about your VUE.
Old Mar 24, 2024 | 09:03 AM
Hunter49x's Avatar
Default Rocker clips
You are correct. There are clips behind the molding. You will need a pry tool to pop them off. Be careful as they are probably getting brittle and are difficult to find.
Old Mar 25, 2024 | 04:58 AM
RustBot's Avatar
Gently pulling by starting at the front, clips did release as I proceeded. Circled area in photo I found, indicates the two clip locations that stayed attached to vehicle. Both were still usable.
Thanks
VueHelper
Mar 29, 2026 12:17 AM
ROKO
Nov 23, 2010 07:14 AM
fiddlebick
Jan 25, 2009 07:37 PM
jilbruke
Jan 28, 2008 01:35 PM
carolb4
Dec 31, 2006 09:03 AM
