2008 Vue Power steering return line
Old Oct 28, 2025 | 09:21 PM
JoeZ's Avatar
Default 2008 Vue Power steering return line
Power steering return line will not stay attached. This is an old picture, since this I have replaced the hose and the clamp with a fuel injection clamp. How far does the hose go onto the fitting, all the way over the ridges? Any help would be appreciated.
Old Oct 29, 2025 | 04:48 AM
3.5L V6.
Seems worth it to just get a new one.
Old Oct 29, 2025 | 08:03 AM
JoeZ's Avatar
This doesn't seem to be what I'm dealing with. There is a longer section of low pressure hose that I need to reconnect. I have a new piece but I can't get the clamps on either end to hold. Was this piece originally connected a different way or do I need to get the end to slide further on the fitting over the ridges?
Old Oct 29, 2025 | 08:09 AM
If it was mine (and it ISN'T), I'd slide the hose past the ridges and put the clamps behind the ridges.
Old Oct 29, 2025 | 10:38 AM
I don’t see which engine but here are a couple. One is for the 3.5 and the other is for the 3.6. Clamps will not hold without a bulb or barb. Even with low return pressure.
Old Oct 29, 2025 | 04:12 PM
I guessed 3.5 L V6, as 2.2 did not have any of that black hose at the end.
Old Oct 29, 2025 | 04:25 PM
Mine is pipe to reservoir
Andy's is gear to reservoir and is in all likelihood the part you are looking for.
Disregard my post above.
Old Oct 29, 2025 | 05:31 PM
I think he has the top one in my post. It has a crimp end that covers the rib shown in his picture.
Old Oct 29, 2025 | 05:36 PM
JoeZ's Avatar
Thanks for the help fellas. Much appreciated.
Old Oct 30, 2025 | 08:54 AM
You need to come back and let us know if you got it fixed or not. If you got it fixed, let us know what you did. Common courtesy.
