2008 Saturn Vue XR Needing Exhaust Soon
Old Mar 25, 2024 | 05:10 AM
RustBot's Avatar
Default 2008 Saturn Vue XR Needing Exhaust Soon
I am going to need exhaust soon. I will only need from behind cat pipes to rear of car including muffler with dual outlets. From what I am seeing online dual pipe setup is discontinued. Anyone have a source or ideas?
Old Mar 25, 2024 | 08:48 AM
Custom muffler shop.
Old Mar 25, 2024 | 01:17 PM
GaryG's Avatar
Thanks for sharing. I just bought an 08 Saturn VUE XR and it has twin exhaust but they are about 3 feet apart from each other. Is yours the same? Have you owned your long? I just needed a 2nd vehicle for my daily driver. It's in the shop now got a water pump going out etc.
Old Mar 25, 2024 | 02:12 PM
RustBot's Avatar
Yes it is the same in the back. I bought it for my daughter a couple of months ago while I was fixing her Equinox which had the PCV plugged up and blew the rear main seal out loosing all the oil and taking the timing chain with it. What a job that was. So now have the Vue back and repaired a misfire issue and discovered the plugs were original with over 111K on them and leaking oil via compression. Decided just to keep the Vue and fix rust issues and exhaust. Use to have a 2005 Vue bought new and traded for a 2019 Equinox that wife drives.
Old Mar 25, 2024 | 10:22 PM
If you do have a custom shop build the replacement for you, make sure you figure out the part number for The 3.6 l with the 6T70 transmission. I think it also matters whether you have FWG or AWD. You'd think they'd be the same between the 3.5 l and 3.6 l, but the comparison / interchangeability engines seem to say no
Lilchief
Headers, Intake, & Exhaust
12
Apr 4, 2024 08:49 PM
19bonestock88
Apr 11, 2018 10:55 PM
BigShoes
Jan 5, 2016 07:58 AM
Anarrafel
Sep 9, 2010 02:35 PM
94503
Apr 11, 2007 01:03 PM
