2008 Saturn Vue Xe not starting
Old Feb 26, 2024 | 06:03 PM
stantheman's Avatar
Default 2008 Saturn Vue Xe not starting
my car stopped turning on so i tapped the starter while someone turned the key and it turned on which i knew i had to replace my starter. next day i replace my starter and it doesn’t want to seem to turn on, so i replaced my battery with a brand new one. still does not want to turn on. does anyone have a clue what this could be if so it’ll help thank you.
video:
https://files.fm/f/yr4a74tg2f
Old Feb 26, 2024 | 08:15 PM
grcauto8453's Avatar
Maybe ignition switch?
Old Feb 27, 2024 | 12:28 AM
stantheman's Avatar
i turn the key all the way and it gives me a slight click but not as loud as it used to be. the battery is giving power to everything else but the starter for some reason
Old Feb 27, 2024 | 08:12 AM
Take the battery cables off, clean them and the cable and reconnect. If that doesn't work, you might not have the starter wires back in the right place or they're loose. It sounds like a bad ground connection to me. Check the battery cables for corrosion while you have them off. Look for a green color of crusty crap on them.
Old Feb 27, 2024 | 10:46 AM
Trip the relay? Does it crank?
Old Feb 27, 2024 | 04:43 PM
stantheman's Avatar
I checked all the bolts including the ones for the battery and made sure they were tight and none of the wires are corroded. there is a little click but i’m not sure if that’s anything. let me know if i did something wrong or if anyone could figure out what this could be
Old Feb 27, 2024 | 04:45 PM
stantheman's Avatar
How do i trip the relay?
Old Feb 27, 2024 | 07:06 PM
You want to jumper 30 to 87. That will put 12 volts on the starter. If the key is on it should crank.
Old Feb 28, 2024 | 03:13 PM
stantheman's Avatar
so i open the hood and then take the fuse box cover off. after im not sure what to do i’m kind of confused? can you maybe explain it a little bit more detailed i’m new to cars and need some knowledge
Old Feb 28, 2024 | 07:52 PM
Swap it with another and see if it cranks. If so, the relay is bad.
