2008 Saturn Vue Hard Starts + Smells like gas
Old Feb 28, 2025 | 10:28 AM
grcauto8453's Avatar
Originally Posted by lostexplorer
I replaced the purge valve solenoid just to be safe. For the 1st couple of days it was fine.Now, the same problem has returned. The good thing is, there is no longer a gas smell coming from my exhaust, but now the smell is coming from my engine area, through my vents at initial startup.
When replacing a purge valve we always blow air through the purge line to make sure there are no charcoal pieces in it. If your canister is bad it can allow for pieces of charcoal to get into the line which will cause the valve to stick.
You need to check the canister and blow out the lines.
Old Feb 28, 2025 | 10:52 AM
lostexplorer's Avatar
Is the EVAP Canister the same as the Charcoal canister which is underneath the left rear passenger side of the vehicle? By air, does compressed air work?
Old Feb 28, 2025 | 11:27 AM
Two names same piece. Compressed air is what we use. Not high pressure.
That1dude
Feb 2, 2025 11:41 AM
JJACOBS6
Jan 14, 2025 08:28 PM
arlonadkinson
May 16, 2023 08:25 AM
notny41
Jun 14, 2018 10:23 PM
SSim
Mar 3, 2011 09:42 PM
