2007 saturn vue error code P0135
Old May 7, 2020 | 05:14 PM
ezsaturnvue's Avatar
Default 2007 saturn vue error code P0135
Hello,
I have 2007 saturn vue 6 cylinder .error code check engine light on P0135, it's O2 sensor bank 1 sensor 1, I took sensor out clean and check meter ohm about 4.5, and reset read code, after turn on engine about 10 minutes error code P0135 come on again, sometime engine light come off and on again, can someone help me out
Thank you very much
Old May 7, 2020 | 09:03 PM
The code is for a heater circuit malfunction on bank one sensor one.
I would check the connector end of the sensor wiring and where it plugs in for any damage. I would then check the entire length of wiring from the connector to the sensor itself for damage. If none is found, the issue is probably inside the sensor itself and the sensor will require replacement.
The fact that the SES light goes on and off indicates to me that it is likely a damaged wire or connection. This is most often inside the sensor base and there's not much you can do about it. The ECM must keep a very small current running through the heater circuit at all times and monitor it in order to ensure the heater circuit is functional. I say this because the purpose of the heater is to get the oxygen sensor up to temperature faster at startup so that it can control the emissions from the engine faster. Under normal driving conditions, it just sits there but is exposed to very high heat which over time will damage many things. If it was an O2 sensor heater fuse, the issue would be constant though I suppose it's possible the fuse has corrosion on it and is bumping around making and breaking contact so check that too
Old May 8, 2020 | 11:55 AM
Thank you very much I will order sensor and replace first
Mobile785
Nov 2, 2019 06:15 PM
Bo0sTeD 4G63
Oct 20, 2019 07:38 PM
Arthur Forgette
Mar 25, 2018 04:55 PM
bigevegas
Feb 23, 2009 07:24 PM
mikes 1994 z28
Jun 8, 2008 07:16 PM
