03 Vue "Reduced power" light
Old Jul 15, 2024 | 01:24 AM
Enjoying the Vue's Avatar
Question 03 Vue "Reduced power" light
Starting the car usually brings up the "reduced power" light almost every time and the only way to fix it is to shut it off and restart it. we just replaced the throttle body and went thru all the relearning processes to try and fix but it still happens.
Old Jul 15, 2024 | 02:31 PM
grcauto8453's Avatar
What codes?
Old Jul 16, 2024 | 05:17 PM
we havent recorded it since the relearning processes, but the ones that showed up before were:
P2176
P2101
P2119
P0638
P2100
So if any of those are related to the relearning count them out
Old Jul 16, 2024 | 07:44 PM
P2176 Throttle Actuator Control System - Idle Position not Learned
P2101 Throttle Actuator “A” Control Motor Circuit Range/Performance.”
P2119 Throttle Actuator Control System - Idle Position not Learned.
P0638 Throttle Actuator Control Range/Performance (Bank 1)
P2100 Throttle Actuator Control System - Idle Position not Learned
I'm thinking the relearn process for the throttle actuator control system was not successful.
Here's what I found for the procedure, although other sources say it must be done with a tech 2 at the dealer. I would venture to guess that a powerful enough scanner could do this as well. But the following is supposedly the manual process.
I find it interesting that it starts by telling you to turn the key to off as the first step. I don't know if that means that the key should be on with the engine running or on with the engine off but as long as you meet the specs in the test either seems it would be okay.
Old Jul 16, 2024 | 07:45 PM
Clear them and see what resets.
Old Jul 16, 2024 | 08:00 PM
Thinking they already did, as that is performed twice as part of the relearn procedure and is the last step.
Can't hurt.
SeaShell08
May 14, 2024 05:16 PM
Chris962
Jan 3, 2024 05:07 PM
Tim Donovan
Feb 10, 2020 08:01 AM
Glenncunning
Apr 23, 2009 10:11 PM
