won't start
Old Mar 20, 2011 | 04:20 PM
slsail's Avatar
Default won't start
Parked the car for a couple weeks.
then it would not start.
Tried starting fluid but nothing.
I borrowed a code reader but get an error it won't download any codes.
this is key on engine off mode.
Could this be crank sensor.
seems to be no or weak spark
Old Mar 20, 2011 | 05:09 PM
If it were my car, here's what I'd do -->
(1) Replace the positive battery cable ... (I suspect it's corroded internally) Also, charge the battery fully.
(2) Replace the CPS ...
Old Mar 20, 2011 | 05:20 PM
slsail's Avatar
CPS ??
sorry what is it
Old Mar 20, 2011 | 05:35 PM
CPS == Crankshaft Position Sensor
Old Mar 20, 2011 | 05:36 PM
slsail's Avatar
will throttle position sensor do the same thing
Old Mar 20, 2011 | 07:07 PM
Nope - TPS (Throttle Position Sensor) has nothing what-so-ever to do with spark ....
Old Mar 20, 2011 | 10:30 PM
bad cps inhibits spark since without it PCM has no idea where crank is in its rotation
Old Mar 21, 2011 | 06:56 PM
slsail's Avatar
ok
replace cps
no change.
so what is next
remember i can not pull the codes I get an error on the code insturment
Old Mar 21, 2011 | 07:21 PM
andre's Avatar
you should try a ignition module or the computer , the crank sensor you can check it with an ohmmeter , . make sure you have 40 psi on the fuel rail.
Old Mar 21, 2011 | 07:52 PM
slsail's Avatar
If i spary starter fluid in the throttle body it should fire if i have spartk right?
tikidude
Aug 30, 2014 05:04 PM
noe g
Jun 4, 2009 05:41 PM
dougporter
May 6, 2009 07:56 PM
wickedhx
Apr 21, 2009 09:28 AM
JayBab
Apr 8, 2009 07:05 AM
