windshield washers
Old Dec 13, 2013 | 12:15 PM
Tinker Unique's Avatar
Default windshield washers
Recently bought an '01 SL1 and the windshield washers do not work. Fluid is full. lines SEEM to be clear - not squirting. Which fuse is "in control" ? NOT marked, and do not have a manual (YET). Thanks for assistance. I know it's a simple fix = just not where to look.
Old Dec 13, 2013 | 08:24 PM
The fuse is located in the Instrument Panel Junction Block (IPJB) ... marked as WIPER. 25 amp. If the wipers operate, the fuse is not the problem ...
Old Dec 13, 2013 | 10:23 PM
Most likely the washer pump motor is clogged with old grease or just burned out. I'd check that if it were mine.
Old Dec 15, 2013 | 05:16 PM
Much thanks, WILL look further when time permits. The wipers work fine. (next day off)
Old Dec 15, 2013 | 08:48 PM
If the wipers work OK, then like Rube says, clogged lines, clogged tank, bad motor -- or a combination of the three
Old Dec 16, 2013 | 10:21 AM
keith's Avatar
I had to replace the pump in mine, its pretty easy to do.
95jive
Jul 18, 2008 08:46 PM
ThaBean
May 14, 2008 08:29 PM
illiano
Sep 16, 2007 07:47 PM
hartman
Mar 22, 2007 02:10 AM
toyo7
Mar 3, 2007 08:28 PM
