transmission shifts hard help please
Old Sep 29, 2011 | 07:44 PM
2saturnfamily's Avatar
Default transmission shifts hard help please
I have a 94 Saturn SL1 with a 1.9L and auto. Yesterday it started shifting hard into 1st, doesnt matter if shifting into drive or, coming to a stop when it goes into first. It also shifts hard into reverse. The ses light is on and it has a transmission code 45 which is Selector Switch no data. Anybody have ideas???
Old Sep 29, 2011 | 08:05 PM
Do a forum search. The subject has been gone over a 1000 times.
Old Sep 30, 2011 | 11:14 AM
ok i searched and i could not find somebody with these exact problems. the car only shifts hard into 1st and rev, shifts fine in every other gear. only has trans axle code 45. i want to believe this is an electrical problem as to for a little while yesterday it did not do it, and ses light went off for awhile, then turned the car off, and when i went to leave again the light came back on and was doing it again. please help with figuring out this problem.
Old Sep 30, 2011 | 12:37 PM
could a malfunction in the vehicle speed sensor cause this problem???
Old Sep 30, 2011 | 12:50 PM
I'm not sure if the VSS would cause this or not. If it were mine though, I'd disconnect all of the connections and give them a good cleaning. Check the wires closely for a bare spot where one of them may be getting grounded too. That's about all I can think of. But keep in mind, that I'm NOT a mechanic.
brantallen06
Nov 14, 2010 08:47 PM
trysten
Jun 10, 2010 10:26 PM
hoseppi
Nov 30, 2009 06:29 AM
terrycabral
Oct 24, 2009 08:35 AM
sally2
Dec 6, 2005 04:17 PM
