Tranny problem
Old Jul 9, 2008 | 03:34 AM
l4zy415's Avatar
Hey guys, I got a question for ya, my GF father drives a 97'' SL2 Automatic. He has no reverse and sometimes its hard for the 1st gear go to second. Do you guys think its the solenoid is messed up or is it the torque converter?
Old Jul 13, 2008 | 02:46 PM
Well , I''m not a repairman, or a transmission guru, but it seems to me that the torque converter is ok, or it wouldn''t go anywhere. The solenoids and valving the direct the fluid through the transmission would be my suspicion. Pull the transmission dipstick and take a sniff at the fluid - does it smell "burnt"? If so, then the clutch disks for the different gears may be bad
Again - strictly my humble opinion .....
Old Jul 14, 2008 | 04:48 AM
IVI4ssacre's Avatar
possible valve body issue. but it sounds more like the input shaft nut came loose.very common on the s series. have to pull the side cover off and retorque nut. i sugguest you bring to the dealer.
Abe'sGST
Sep 19, 2015 09:51 PM
twobegenius
Sep 1, 2012 09:09 AM
1kevinmac
Mar 6, 2011 08:52 PM
boogawooga
May 24, 2006 10:17 AM
HeatherP00
Nov 8, 2005 03:35 PM
