throwin' codes!!!
Old Jun 25, 2012 | 06:02 PM
jspd234's Avatar
Default throwin' codes!!!
1999 sw1, alritey boys n girls, i have codes: po732, po733, po734. goes alright from a stop, then wont upshift and engine free spins with no trans engagement until i come to a stop. any ideas? thanks!
Old Jun 26, 2012 | 07:59 AM
Ayup -- Them's transmission failure codes, alright. Looks like a transmission teardown might be in order, but check your IGN3 fuse in the instrument panel junction box (IPJB) first, and also replace the A/TRAN relay in the under hood junction box (UHJB). You might just get lucky
Old Jun 26, 2012 | 02:11 PM
jspd234's Avatar
checked all fuses, they are good. could not find a/tran relay in uhjb. nothing is labeled like that. where is it located?
Old Jun 26, 2012 | 03:26 PM
As I recollect, look at the UHJB in such a manner so that the relays kinda looks like the letter "L" (down the left side and across the bottom) The tranny relay should be the one on the bottom row -- far right
Old Jun 26, 2012 | 05:11 PM
might this not be valve body related?
Old Jun 26, 2012 | 06:48 PM
jspd234's Avatar
i'm thinking solenoids or valve body maybe? heres my uhjb by the way.
Old Jun 26, 2012 | 11:54 PM
AArrgghhhhhhhhhhhhhhh
I'm lookin at the wrong sheet!!!
Old Jul 4, 2012 | 12:38 PM
jspd234's Avatar
swapped out the wrong pcm to a pcm out of a 99 sw1 and ......voila!!!! everything works properly!!
henrylford
Aug 12, 2006 10:13 AM
calmb4dastorm
Jul 7, 2006 12:11 AM
Turbochump
Jun 7, 2006 04:28 PM
mikes 1994 z28
Mar 27, 2006 04:47 PM
bam_bam1ca
Nov 15, 2005 12:08 AM
